1995 Ford Escort flashing battery light
STILLWATERGAIL
Electrical problem
1995 Ford Escort 4 cyl Four Wheel Drive Manual 160 K miles
Left the lights on one night - next day the battery was dead - had batter recharged, worked good for a couple days. Then battery lights started flashing - replaced a battery connector that was cracked and thought that would take care of the problem - but a couple days later the battery light started flashing again. Do you think the alternator needs to be replaced? Is the regulator inside the alternator?
Nov 5, 2008 at 1:39 AM
BMRFIXIT
  • 19,053 POSTS
Start engine and check battery volts if less than 13.5V alternator no good
need manual CHECK IT @
http://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 5, 2008 at 11:42 AM
