Bought used, ran for 2 weeks then just died, Have replaced ignition Control Module, have tested battery, will turn over but not fire. What next?
Jan 11, 2009 at 3:01 AM
DAVE H
✓Experienced Mechanic
check inertia fuel cut off switch..fuel pump fuse ..fuel pump ..fuel pump relay...fuel pressure ...check if it is getting spark .. also check the timing belt is still intact ?
