1995 Ford Escort Engine will not fire
179,000 MILES • 4 CYL • 2WD • MANUAL
SEE
Bought used, ran for 2 weeks then just died, Have replaced ignition Control Module, have tested battery, will turn over but not fire. What next?
Jan 11, 2009 at 3:01 AM
DAVE H
  • 13,383 POSTS
check inertia fuel cut off switch..fuel pump fuse ..fuel pump ..fuel pump relay...fuel pressure ...check if it is getting spark .. also check the timing belt is still intact ?
Jan 11, 2009 at 10:34 AM
