When I pull away from a dead stop the engine seems to flutter and has no power. I feather the gas pedal an the problem goes away. this will happen only once or twice a day. Not every day. I have put in new spark plug wires, new fuel filter,new ign. coil and ran fuel injector cleaner through the system. I have also cleaned the element in the Mass air flow sensor.I've run out of ideas. It's the wifes car and if I can't fix the problem, she wants a new car. HELP
Oct 6, 2009 at 2:11 AM
