1995 Ford Escort cooling fan
1995 FORD ESCORT
49,645 MILES • 4 CYL • FWD • AUTOMATIC
GILBERTSERRA
cooling fan stays running when key is on and engine is cold, I replaced temperature sending unit that controls fan and had fan relay checked, and it checked out OK.
Feb 18, 2009 at 7:51 PM
BMRFIXIT
  • 19,053 POSTS
If no after market wiring done on it
and if so need to check that
check for codes
if all OK suspect bad relay
I would look again at the wiring
Feb 18, 2009 at 10:11 PM
