1995 Ford Escort Clutch Question
142,000 MILES • 4 CYL • FWD • MANUAL
JWRINKLE1
The clutch and slave cylinder was replaced about 5000 miles ago.
The problem is when the car is running it will not go into any gear.
When the car is off it will go into all gears.
Apr 23, 2008 at 4:27 AM
  • 31,937 POSTS
Hi there,
start by inspecting the back of the master Cly for leaks, just check under the dash where the clutch pedal is, if leaking replace and re bleed. if ok, check that there is still no air in the system. re post if you still have an issue
Mark (mhpautos)
Apr 23, 2008 at 11:10 PM
