1995 Ford Escort Clutch adjustment
150,000 MILES • 4 CYL • 2WD • MANUAL
PISTOLPETE
My clutch seems to need adjusting. How do I go about this? My car in the morning does not want to go into gear easily. But once I warm it up, and get going, it seems to shift better. This morning when I started it up(I left it in 1st gear) I had my foot on the clutch, but it wanted to start rolling forward anyway.
Peter
Feb 5, 2009 at 12:29 AM
BOWTIE BABY
  • 101 POSTS
Is it a clutch cable or a hydraulic clutch? If its a cable there will be an adjusting nut on the cable where it goes through the fire wall. It will be next to the master cylinder and brake booster, a little towards the fender. Loosen the nut until you have about 1 inch of free play in the pedal.
Feb 5, 2009 at 5:38 PM
PISTOLPETE
I believe it is hydraulic.
Peter
Feb 5, 2009 at 11:42 PM
BOWTIE BABY
  • 101 POSTS
Im not exactly sure how to adjust that type. My brother has a book for that car, I will get it when he gets home and check on it. Might take a couple days but I will do it as soon as I can.
Feb 7, 2009 at 8:58 AM
BOWTIE BABY
  • 101 POSTS
My bro cant find his book but the hydraulic type should not require adjusting. There should be a bleeder vavle on the slave cylinder and you can bleed it like you do brakes.
Feb 13, 2009 at 6:18 PM
