1995 Ford Escort Click when coasting
140,000 MILES • 4 CYL • FWD • MANUAL
SPIKIE
My '95 Escort manual transmission has a distinct "click" when it coasts against compression or with the clutch disengaged, a less distinct click when loaded. This can be heard, and can be felt through the shifter. The problem becomes more apparent the faster the car is driven.
Is the problem more likely to be in the transmission or in the driveshaft(s)?
Nov 23, 2008 at 5:45 AM
BMRFIXIT
  • 19,053 POSTS
As the car moving step on the clutch does the noise goes out and if so suspect clutch bearing
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 23, 2008 at 9:51 AM
