1995 Ford Escort calipers
1995 FORD ESCORT
175,000 MILES • 4 CYL • FWD • MANUAL
KELLY_077
  • 6 POSTS
i've noticed a noise from my front wheel recently. I looked at the brakes and the caliper seems to be loose. I'm not sure if i would be able to fix it and how. The caliper has been changed in the last 2 months. i don't know if it needs to be changed, or just fixed. Can you please give me some information
Mar 4, 2009 at 1:31 PM
BLACKOP555
  • 10,386 POSTS
you dont have a fixed caliperit is a floating caliper. it moves freely and you can move it with force from the hand. as long as teh mounting bolts are properly torqued it will have the proper amount of play.
Mar 4, 2009 at 1:37 PM
KELLY_077
  • 6 POSTS
but the caliper on the brakes on the right side is tight. the left side moves and rattles when i drive
Mar 4, 2009 at 2:01 PM
BLACKOP555
  • 10,386 POSTS
ok. make sure that the caliper mounting bracket bolts that mount the bracket to the knuckle is torqued properly and no play is noted. next step is to properly torque teh caliper mounting bolts.
Mar 4, 2009 at 2:03 PM
KELLY_077
  • 6 POSTS
awesome...thanks ill give it a try :)
Mar 4, 2009 at 2:07 PM
BLACKOP555
  • 10,386 POSTS
let me know what you find.
Mar 4, 2009 at 2:14 PM
KELLY_077
  • 6 POSTS
i'll get back to you tomorrow. i won't be doing it tonight.
thanks
Mar 4, 2009 at 2:17 PM
BLACKOP555
  • 10,386 POSTS
so what have you came up with?
Mar 6, 2009 at 3:04 PM
KELLY_077
  • 6 POSTS
it turns out my caliper was missing a bolt...so i took it off, checked it all out and put a new bolt in the top...all's good...thanks for the help!
Mar 6, 2009 at 7:37 PM
BLACKOP555
  • 10,386 POSTS
good thing it was just a bolt. glad to hear i was able to somwhat help.
and glad to hear you ahve your problem fixed.
Mar 7, 2009 at 2:38 AM
KELLY_077
  • 6 POSTS
haha yea, so my car's alright for now...till a few weeks from now when something else goes wrong...
im sure i'll be back for some more help
but untill then, thanks :)
Mar 7, 2009 at 2:41 AM
BLACKOP555
  • 10,386 POSTS
Ill be here if yhou get another problem, i hope you dont, but if you do have to post back, try to make a separate post that way these two are separate, and you can just pm or email me a link to it so i can look at it if you want.
Mar 8, 2009 at 4:48 AM
