1995 Ford Escort blower motor not working/no fan for heat/A
75,000 MILES • 4 CYL • FWD • AUTOMATIC
RHINMAN
Is there a fuse either in the cabin or under the hood that applies to the blower
Aug 12, 2008 at 4:11 AM
LINDAJESSIE
  • 16 POSTS
i just had mine replaced, very comon problem in these cars. you may need to replace the blower motor,($50-60.) the spinning thing inside gets frozen stiff and wont rotate after so many years, (mine '97), also the sensor ($15.ish) is right next to blower motor and it all should be right under the passengerside dashboard, under glovebox. a few nuts and bolts but just remember how it came out, step by step to make it easier to put the new one in. 15-20 minuts tops. good luck, also got to auto zone and talk to them, they are a great bunch of people when you need to be sure of something.
Aug 14, 2008 at 5:12 PM
