1995 Ford Escort Blower motor & or resistor
TX_WOLFMAN
  • 18 POSTS
Electrical problem
1995 Ford Escort 4 cyl Two Wheel Drive Manual
Blower only works on lower speeds. Once in a while it will blow on lower speeds for a few seconds then shut off, then it might work all the time on lower speeds only. Would it be the motor, switch, or resistor?
Dec 6, 2009 at 5:06 AM
BLUELIGHTNIN6
  • 16,542 POSTS
first check blower motor relay
Dec 6, 2009 at 7:05 AM
TX_WOLFMAN
  • 18 POSTS
I checked and there is no relay on this model. So I did a voltage check, there was 12 volts to the motor so the motor was good. Looked at the resistor and one wire was fried, so I replaced the resistor and pigtail and all is fine. Thanks for the reply.
Jan 2, 2010 at 7:53 AM
