1995 Ford Escort Battery Terminals
VTCAROL50
  • 22 POSTS
I'm getting an acid buildup on my battery terminals which is preventing the car from sometimes starting?
Can I replace the terminals to correct this problem or is it a problem with the battery itself, that is throwing out this acid?
Any suggestions appreciated.
Jan 23, 2007 at 2:41 AM
MATHIASO
  • 1,209 POSTS
check the cables for continuity if they are bad replace them, check your battery with an ohmeter.
the acide build up may have cause shorted cell .
Test it, recharge it or replace it.
Sometimes battery failure is not the fault of the battery at all. It may be caused by a bad starter, a defect in the charging system, or just a loose belt.
Check those things too.
Jan 23, 2007 at 3:17 AM
