This is my first time trying out forums for advice on the car, figured I'd give it a shot.
This is my problem
My clutch peddle seems to have zero resistance 90% of its way down when I attempt to push it down. The last 10% actually seems to "catch" any sort of resistance and barely depresses enough for me to put the car into gear, let alone change gears.
If I give the engine gas it seems to gain more resistance and is slightly easier to use the clutch. Like 80% of the way down is nothing, and 20% I have resistance.
The fluid was low a day ago when I checked, just filled it up a few hours ago and nothing has seemed to change. The fluid is still full, but no change to the clutch. Any ideas?
Thank you for any assisstance!!
-Mike
This is my problem
-Mike
Nov 15, 2007 at 5:52 AM
