1995 Ford Escort
MEK22
Engine Performance problem
1995 Ford Escort 4 cyl Front Wheel Drive Manual
My car sounds like its missing and when im driving it i go to push the gas to the floor and then it dies down and have to down shift to pick speed up then dies down again
Mar 17, 2010 at 4:52 AM
DAVE H
  • 13,383 POSTS
LOSS OF POWER
Check air intake system. Also, ensure throttle plate and linkages operate properly.
Check ignition system. See BASIC TESTING - 4-CYL article in the ENGINE PERFORMANCE section.
Check fuel delivery. Refer to the appropriate SYSTEM/COMPONENT TESTS - EEC (1.8L) article in the ENGINE PERFORMANCE section.
Check for restricted exhaust system.
Check EGR system. Refer to the appropriate SYSTEM/COMPONENT TESTS - EEC (1.8L) article and TESTS W/CODES - EEC 1.8L article in the ENGINE PERFORMANCE section.
Check engine compression. Check engine mechanical condition. Check timing belt, intake manifold gasket, camshaft and valves.
Perform QUICK TEST. See TESTS W/CODES - EEC 1.8L article in the ENGINE PERFORMANCE section.
On M/T models, ensure clutch is operating properly.
On A/T models, ensure transmission is operating properly.
Check for dragging brakes.
Mar 17, 2010 at 10:53 PM
