1995 Ford escort
1995 FORD ESCORT
VICDIESEL83
I have a 1995 ford escort and the passenger side window doesn't work it seem as theres no power going to the window, i check the fuses and there all good.... can you help me out??
Jul 8, 2007 at 12:37 PM
JWALTH02
  • 180 POSTS
Have you checked the switch? Make sure the wires are all connected or have good connections if loose. Then check the wires as far back as you can inspecting for damage.
Jul 8, 2007 at 1:13 PM
VICDIESEL83
i have checked the switch and the wires and its still doesn't work
Jul 8, 2007 at 1:31 PM
JWALTH02
  • 180 POSTS
Do you have access to a voltmeter? If not you can get a decent one from walmart for around $15-20. Need you to test the wires and see if you are getting power or not.
Jul 8, 2007 at 1:35 PM
