1995 Ford Escort
ROMEO1
  • 5 POSTS
1995 Ford Escort 4 cyl Two Wheel Drive Automatic
95 escort shakes and stalls when i put it in gear. i already changed the fuel filter. stays running if i put it in neutral. when i get it going and i caome to stop sign it cuts off, starts back up after a few cranks.
Jun 8, 2008 at 10:46 AM
BMRFIXIT
  • 19,053 POSTS
I would check it for tune up
plugs and wires ….
Check and clean throttle body and idle air control valve
Jun 8, 2008 at 11:28 AM
ROMEO1
  • 5 POSTS
where is the air idle valve located?
Jun 8, 2008 at 2:55 PM
BMRFIXIT
  • 19,053 POSTS
On the intake manifold by the throttle body
Jun 9, 2008 at 10:02 AM
ROMEO1
  • 5 POSTS
now when it is warm and i put the car in gear it shakes and rattles and sound like a diesel clanking then it cuts off, please help
Jun 9, 2008 at 3:06 PM
BMRFIXIT
  • 19,053 POSTS
did you do any work on it ?
check your fluids
check EGR valve
Jun 10, 2008 at 6:39 AM
ROMEO1
  • 5 POSTS
I changed the spark plugs, tsp, oil and air filter. should I change the air idle valve what should check for on the egr valve .
Jun 10, 2008 at 8:39 AM
BMRFIXIT
  • 19,053 POSTS
you should remove the idle air control valve and clean it 1st
Jun 10, 2008 at 1:06 PM
ROMEO1
  • 5 POSTS
i replaced today and same problem
Jun 10, 2008 at 3:31 PM
BMRFIXIT
  • 19,053 POSTS
(1) Check vacuum lines
disconnect vacuum hose at EGR valve and connect vacuum gauge to hose
disconnect idle air
start engine and accelerate engine to 2000 -2400 RPM and release throttle
repeat 8-10 times and check for consistent response
with engine at normal operating temp vacuum should raise above 15in Hg and return to zero when throttle is release
(2) is the engine running smooth at idle and in neutral ? check ignition wires and coil
(3) I don’t like the diesel sound effect you are talking about and it need to be investigated check all the basics
Jun 10, 2008 at 10:43 PM
