After replacing the clutch cylinders, master and slave, my car started to rattle a bit and now is running very rough at idle and in low gears, most noticeably. I just had the spark plugs and wire replaced. It had a timing belt and water pump replaced at 92,000. Could it be fuel filter? That hasn't been replaced since 84,000.
SPONSORED LINKS
Friday, August 7th, 2009 AT 8:27 PM
