1994 Ford Escort loss of electrical power
92,000 MILES • 6 CYL • FWD • MANUAL
SJ-B
when ignition turned on, all relevant lights appear on the panel. when key turned to start there is a click then a total loss of electrical power. If I disconnect the battery then reconnect I get power back, sometimes it will then start, but I may have to disconnect & reconnct the battery several times
Oct 15, 2010 at 10:10 PM
BILLYMAC
  • 2,204 POSTS
this sounds like bad batt connections or bad connection at the starter solenoid
Oct 30, 2010 at 12:46 PM
