1994 Ford Escort Leaks
1994 FORD ESCORT
75,598 MILES • 6 CYL • 2WD • AUTOMATIC
TCREID316
My girlfriends 1994 ford escort has a transmission fluid leak what would be the best way to fix it? I suggested trying some transmission fluid sealer like bars leak or white shepard but she tells me need to replace all the hoses . How would I go about checking for the spots that could be leaking and or hopefully not fixing the whole transmission fluid hoses. If it comes to that how would I replace all those hoses?
Jan 13, 2010 at 7:24 PM
BMRFIXIT
  • 19,053 POSTS
Bar stop leak will not work in your tranny
and I would not use it
have to wash, clean the area
check and locate the leak
fix, repair, replace as needed
Jan 13, 2010 at 10:20 PM
