1994 Ford Escort
SHAK1888
  • 1994 FORD ESCORT
  • 4 CYL
  • AWD
  • 60,000 MILES
I HAVE FORD ESCORT 94 1.9 4CYL 6000 MILES. IT STARTS RIGHT AWAY WHEN I GO UP THE HILL IT LOSES POWER AND GOES TO 5 MILE AN HOUR IT DOESNT GET HOT AND ALSO THERE IS WHITE SMOKE COMEING FROM PIPE TOO I CHANGED SPARK PLUGS AND FUEL FILTER PLEASE HELP ME. THANKS
Saturday, September 26th, 2009 AT 11:56 AM
White smoke on the tail pipe indicates coolant is burning in the cylinders could mean a blown headgasket, cracked head or block
Loses power up hill could be caused by the follwoing:
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Saturday, September 26th, 2009 AT 2:57 PM
