1994 Ford Escort fuel injector
CRIPPLEDCARPETMAN
Electrical problem
1994 Ford Escort 4 cyl Two Wheel Drive Manual
Won't Start!Have fuel and spark,no pulse at injector also has vibrating noise from box under drivers seat?Any help appreciated.
Jul 8, 2008 at 9:17 AM
KHLOW2008
  • 41,812 POSTS
Hi crippledcarpetman,
No injector pulse means the ECM is not giving the signal.
Was the check engine light showing prior to engine not starting?
I would suggest checking the cam and crank sensors.
Jul 9, 2008 at 2:16 AM
CRIPPLEDCARPETMAN
Thank for replying.There wasn't a check engine light.I've since found the timing belt to be bad.Any idea if the elect. box under the drivers seat is the computer and why it would vibrate?Thanks
Jul 9, 2008 at 9:48 PM
SERVICE WRITER
  • 9,123 POSTS
Not sure on the vibration, but that engine is an interference engine, meaning pistons and valves can collide when it goes out of time. You may have internal damage.
Jul 9, 2008 at 10:14 PM
CRIPPLEDCARPETMAN
Put new timing belt on ,found water pump frozen up .Got it back together and fired right up.Still need to test drive.Thanks for your help.
Jul 11, 2008 at 11:12 PM
