1994 Ford Escort front struts
141,000 MILES • 4 CYL • FWD • AUTOMATIC
PAPERKNIGHT
It seems that the right front struts make a sqeeking sound or a sound like rubber rubbing. It does not happern all the time, only on certain bumps and when I make a left turn. Recently had the tie rods replaced on the right front side. Do I need to replace the front struts? And if so, can I only replace the right side strut?
Feb 13, 2009 at 7:43 AM
BILLYMAC
  • 2,204 POSTS
hi yes strut should be replaced and have the ball joints checked as well. you can replace one strut but we would reccomend both .billymac
Feb 13, 2009 at 7:49 AM
DOCFIXIT
  • 18,828 POSTS
If struts are original then yes replace you should be on tird set at milage. Need to be replaced as pair.
Check Gooyear,Sears, Firestone etc. They will have specials
Feb 13, 2009 at 7:51 AM
