HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
General
Fuse Test
1994 Ford Escort fan won't run
WINNINGSIDE1
MEMBER
1994 FORD ESCORT
4 CYL
FWD
AUTOMATIC
197,000 MILES
Replaced fan motor&fan temp-switch&fuse still won't run
Friday, July 17th, 2009 AT 9:02 PM
BLUELIGHTNIN6
MECHANIC
Does fan come on when A/C is switched on?
Friday, July 17th, 2009 AT 9:55 PM
WINNINGSIDE1
MEMBER
Car does not have a/c how ever I did fix problem
Sunday, July 19th, 2009 AT 7:54 PM
Please
login
or
register
to post a reply.
Related Fuse Test Content
Fuse Identification
I Need A Diagram For The Fuses Please
Asked by
nonina
1 ANSWER
3 IMAGES
1997
FORD ESCORT
1999 Ford Escort Blow Fuse
My Escort Keeps Blowing The 30a Fuel Injector Fuse Under The Hood. The Fuse Blows When Turning The Key To The Start Position. Replacing The...
Asked by
fixitfast
1 ANSWER
1999
FORD ESCORT
What Does Btn Fuse Stand For.
Btn Circuit Is Drawing Voltage At All Times Killing Battery
Asked by
rockydog
1998
FORD ESCORT
1999 Ford Escort 100 Amp Main Fuse Blows When...
When I Chaged The Battery In My 99 Ford Escort The Blue 100 Amp Main Fuse And The 10 Amp Fuse Inside The Car Keeps Blowing Ive Changed The...
Asked by
kingced83
1999
FORD ESCORT
2001 Ford Escort Blown Fuse
The 10 Amp Fuel Injector Fuse Under Dash Keeps Popping When I Turn On Key. Dead Short At The 30 Amp Fuse Under Hood.
Asked by
bmoyer
1 ANSWER
2001
FORD ESCORT
VIEW MORE
Change Oil and Filter 6.0L Chevrolet
Misfire
Cooling System Flush
