1994 Ford Escort creaking noise
SHIFTY2410
Noises problem
1994 Ford Escort Front Wheel Drive Manual 100000 miles
I have a 1994 escort cabriolet and when i am driving slow or turning i have a creaking noise like someone stepping on loose floor boards !!! Its not there when driving at normal speeds. Please can some1 help. Cheers
May 30, 2009 at 7:17 AM
BMRFIXIT
  • 19,053 POSTS
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_377.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic2_177.jpg
Was the front end checked ? ball joints and tie rod ends also check the bushings ***************************************** need manual CHECK IT @ https://www.2carpros.com/kpages/auto_repair_manuals.htm
Jun 4, 2009 at 2:05 PM
SHIFTY2410
Thanks 4 reply. It had new wishbones both sides about 1yr ago and i dont do big mileage. I will check the bits in ur diagram tho. Thanks again
Jun 6, 2009 at 7:15 AM
