1994 Ford Escort Coolant steam from exhaust
72,000 MILES • 4 CYL • FWD • MANUAL
RELIC HUNTER
i am getting a lot of steam from the exhaust
I replaced the
Freeze Plugs
Head Gasket
Water Pump
Thurmostat
Intake Manifold Gasket
Exhaust Manifold Gasket
Engine does need a flush and i suspect it is Raditor clogged or Catalytic Converter clogged.
Thanx for all your help.
Jan 18, 2008 at 6:14 AM
CRAIGFL
  • 89 POSTS
You need to verify that you truly getting coolant into the exhaust as you suspect. This could be a cracked head or block if the engine overheated. A compression test of each cylinder and/or a pressure test of the cooling system should reveal this leak.
Jan 18, 2008 at 9:45 PM
