1994 Ford Escort compression
MY_POS_ESCORT
1994 Ford Escort 4 cyl Front Wheel Drive Manual
i need the specifications for the compression in the cylinders
Mar 15, 2010 at 3:14 PM
BLUELIGHTNIN6
  • 16,542 POSTS
lowest compression reading should not be less than 75% of highest compression reading. cylinder compression readings should not be less than 100 psi
Mar 15, 2010 at 3:20 PM
