1994 Ford Escort clutch
1994 FORD ESCORT
151,000 MILES • 4 CYL • FWD • MANUAL
JASON ROW
The car has been sitting for about a year.
You can start the car in neutral but it wont go into gear.
If you start the car in gear with the clutch in , it lounges forward as if you don't have the clutch in?
Sep 29, 2010 at 4:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
make sure the clutch fluid is full, if it is then try bleeding the system. if that doesn't help then you probably have a failed slave cylinder
Sep 29, 2010 at 5:16 PM
