1994 Ford Escort Battery is not charging
190,000 MILES • 4 CYL • FWD • MANUAL
COMPUTERDR911
My 94 ford escort died while in motion last week. I had the battery tested and found that the battery had bad cells. After replacing it a few days later the car died again and would not start or even jump. So I took the new battery in and founf that it was bad as well. After replacing yet a nother battery I had the car tested at the local auto parts store. the alternator was only putting out 6 amps. so I replaced the alternator. A day later after driving at least 50 miles the car did again the same thing... it died and will not jump start. I am assuming I have yet another bad battery that wasn't getting charged properly. Some one suggested since I had already replaced the alternator that I should look at the Voltage converter? any ideas?
Feb 13, 2008 at 1:22 AM
  • 75,988 POSTS
Did you check all the fuses involved with the charging system if not see below? You can disconnect the wire harness behind the alternator and jump A to F this will bypass the regulator and alternator should put out everything its got
https://images.2carpros.com/forum/automotive_pictures/12900_alty_8.jpg
Feb 13, 2008 at 4:33 AM
