1994 Ford Escort altenator
1994 FORD ESCORT
185,000 MILES • 4 CYL • FWD • MANUAL
JROCK1223
hello, i bought this car used, upon driving it home it died on the interstate. it runs great, but the battery keeps dieing, i bought a used altenator that bench tested fine,put another battery that also tested fine and drove it ten or so miles,after i cut the car off it would not restart till i got another jump.i put on a new drive belt and still the same problem.could it still be my altenator?
Feb 24, 2008 at 6:25 AM
MERLIN2021
  • 17,250 POSTS
Is the charge indicator on when the car is running? does it come on with the key on engine off? Hook up a voltmeter to the battery, you want to see 13.8-15volts. Check the condition of both cables, at both ends. Remove neg(-) cable first, and put it on last.
Check the underhood fuses in the power distribution center.
Feb 24, 2008 at 6:31 AM
MERLIN2021
  • 17,250 POSTS
To: merlin2021
Posted: Sun Feb 24, 2008 3:45 pm
Subject: follow up
where would i see a charge indicator light? the cables were wedged with a nail, but it runs fine when jumped, at least for a while. i have no access to a voltometer but i have a test light. does that help? just because the altenator passed a bench test can it still be bad?
Answer to PM:
If cables are NAILED on, a carpenter must have owned this one eh? Please do me and you a big favor, lets change the cable(s) that are nailed on....
Feb 24, 2008 at 6:50 AM
