1994 escort
LILGANGSTA_5589
my 1994 escort has been sitting for a little over a year now. i started it a few times at first and havent started it for a while now. the engine turns over but wont start. i checked the fuel cutoff switch and various other items . im not sure if the gas is bad or the plugs or what.
May 8, 2007 at 7:36 PM
CRAIGFL
  • 89 POSTS
As with all these Escorts, you need to be sure the timing belt isn't broken or stripped. When you crank, look under the timing belt cover on top to be sure its turning...
May 9, 2007 at 12:41 AM
