1993 Ford Escort The radiator fan
1993 FORD ESCORT
SGT. FOX
Engine Cooling problem
1993 Ford Escort 4 cyl Front Wheel Drive Automatic
Why wont the fan on my Ford Esscort LX 1993 turn on without the A/C being on. The fan does turn on when the A/C is turned on. I have tried replacing my thermostat, and the temp. sensor that tells the fan when to kick on. I looked around for faulty and/or detached wires, and for wiring problems. my car continues to overheat because the fan will not kick on. Please help me figure this out, i am extremely confused by this. Thanks.
Aug 13, 2010 at 3:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
check for faulty radiator fan relay(s)
Aug 13, 2010 at 3:54 PM
SGT. FOX
[quote:8940480aeb="bluelightnin6"]check for faulty radiator fan relay(s)[/quote:8940480aeb]Lol that's going to be fun yeah ok thanks i'll check it out i really appreciate the help
Aug 15, 2010 at 5:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
should have 2 of them, a high speed and a low speed. both are on the left front inner fender panel, left of the air cleaner assembly. to learn how to test a relay check out the link below..
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm
Aug 15, 2010 at 5:51 PM
SGT. FOX
[quote:3ac04b6b34="bluelightnin6"]should have 2 of them, a high speed and a low speed. both are on the left front inner fender panel, left of the air cleaner assembly. to learn how to test a relay check out the link below..
https://www.2carpros.com/how_to/how_do_i_check_a_relay.htm[/quote:3ac04b6b34]ok so i have purchased and changed the fuse and it did not help. no faulty wires or relays. Still confused any ideas?
Aug 17, 2010 at 12:28 PM
BLUELIGHTNIN6
  • 16,542 POSTS
never said to replace fuse but OK. if relays fuses and wiring is good and ECT sensor has been replaced than the PCM (powertrain control module) is at fault.
Aug 17, 2010 at 2:20 PM
