1993 Ford Escort Problems Starting
140,000 MILES • 4 CYL • FWD • MANUAL
LARSON1
I am having problems with starting. It is a GT so it has a 1.8L. I have replaced the fuel filter, fuel pressure regulator, plugs, wires, cap, and rotor. Also within the past few weeks it is starting to miss at low RPM's. I just checked the timing belt on it also. And everything seems to be fine. Just wondering what you think.
Nov 12, 2008 at 3:53 AM
ZACKMAN
  • 4,202 POSTS
Start with your ignition timing. It should at 10 degrees BTDC. Then check for vacuum leak.
Nov 12, 2008 at 1:32 PM
