1993 Ford Escort not s****** in to th4 gear
83,250 MILES • 6 CYL • 4WD • MANUAL
EXPLORER2
Okay i got all of these gear's 1st 2nd 3rd 5th R/ 4th gear is there but when i go to put it it grinds an pop;s right back out !! what an where do i go to look at it!! new trans an all thing's that in to it is new to top it off!!
May 16, 2010 at 2:19 AM
  • 110,248 POSTS
It sounds like the syncronizer is bad for that gear. You will need to remove the trans and take it apart to check it. Before that, make sure the fluid is full and clean.
May 26, 2010 at 1:23 AM
