Every time I push the neutral safety switch in, the stater cranks over without the key in the ignition. The car will start if I put the key in and turn it on. I can still shift gears and move if I push the clutch halfway in. But with the car on and if I push the clutch all the way in, you can hear the starter cranking. I have replace the neutral safety swiitch and the problem still exist. What else could be the cause?
Jul 29, 2008 at 3:43 PM
