1993 Ford Escort Need help?
MDB1342
Electrical problem
1993 Ford Escort 4 cyl Two Wheel Drive Manual 150K miles
The lights on the dash dont work like the seatbelt light, the battery sign, and the check engine sign and neither do the turn signal. the car wont start and i thought it was the battery but i took it to autozone and had them charge it. we put the battery back into the car and it still wont start. the headlights come on and the lights on the inside of the car work. what do you think is wrong with it?
Jan 25, 2009 at 9:22 AM
DAVE H
  • 13,383 POSTS
check the ignition switch is working correctly ..also check the manual lever position sensor !
Jan 25, 2009 at 12:48 PM
