1993 Ford Escort How to troubleshoot engine cooling fan
94,000 MILES • 4 CYL • FWD • AUTOMATIC
JIMINPA
How do I determine if a fuse or relay is faulty on the radiator cooling fan, or if the fan itself is bad? The car overheats, I can't locate any leaks, and the fan is not running when the engine is hot.
Mar 8, 2009 at 7:57 AM
HELPING YOU
  • 100 POSTS
put power & ground to fan first...
Jun 6, 2020 at 5:48 AM
BRITISHDOLL161985
i'm having the exact same problem, have you tried changing out your thermostat, or the thermostat sensor?
i beleive to see if it's the fuse it is under the steering wheel, i can't seem to find it anywhere under the hood.
