1993 Ford Escort help !
106,394 MILES • 4 CYL • FWD • MANUAL
KEVINSHOCKLEY1981
i was going down the road and the car just died ...the battery was dead so i thought the altonator was bad i replaced that and nothing again ..the new one in the car will not charge the car .Could it be a relay causeing the altonator not to be chargeing the battery ?
Jan 12, 2008 at 7:15 AM
BMRFIXIT
  • 19,053 POSTS
[quote:4e6a75776c="kevinshockley1981"]Electrical problem
1993 Ford Escort 4 cyl Front Wheel Drive Manual 106394 miles
i was going down the road and the car just died ...the battery was dead so i thought the altonator was bad i replaced that and nothing again ..the new one in the car will not charge the car .Could it be a relay causeing the altonator not to be chargeing the battery ?[/quote:4e6a75776c]
my question to you is
alternator with or without voltage regulator
if without
check and or replace regulator
check power supply to alternator
let me know
Jan 12, 2008 at 2:04 PM
SPARKYZX2
to add to what the other guy said you may have a bad battery
Jan 12, 2008 at 2:08 PM
