1993 Ford Escort Gas leak, won't start
73,000 MILES • 6 CYL • FWD • AUTOMATIC
PITTCOP983
My Escort began to lose power. My daughter pulled over because the Check Engine Light came on. The vehicle would not start back up and when I tried it gas began to come from the front part of the engine. It does not leak gas while just sitting only when I try to start the car.
Please help.
Jul 24, 2009 at 8:26 AM
BUDDYCRAIGG
  • 2,262 POSTS
it's only leaking when you are trying to start it cause the fuel pump doesn't run when it's just sitting there.
have a helper turn the key while you are looking for the fuel leak under the hood.
Jul 24, 2009 at 11:31 AM
PITTCOP983
[quote:32ed4d3c2e="pittcop983"]Engine Performance problem
1993 Ford Escort 6 cyl Front Wheel Drive Automatic 73,000 miles
Please help.[/quote:32ed4d3c2e]
So what your saying is it could be the fuel pump or a gas line??
Jul 24, 2009 at 4:38 PM
LAZYGAZER
  • 68 POSTS
The problem is the gas line in the engine compartment. Have someone crank the engine while you look for the leak.
For safety have an extinguisher closeby in case of fire you are dealing with a flamable liquid.
Jul 30, 2009 at 1:38 PM
BUDDYCRAIGG
  • 2,262 POSTS
I'm sorry I missed your last question on the 24th, i did not get an email notification that there was another post to the thread.
what [b:498f34ce96]lazygazer[/b:498f34ce96] said is correct.
Jul 30, 2009 at 2:13 PM
