Hello. I have a problem with my Ford Escort. I hooked a loose wire up to my cooling fan, I have a 1.9L 4cyl, 88HP. It was in the engine bay, and, since I just bought this vehicle, I asked the owner where it went. He said to the fan. I tried this, and my fan doesn't work. If I idle, it heats up but when I'm driving, It's fine. Any ideas? Checked relays behind my intake and fuses. Didn't find any faults. Also checked interior fused. All good there. My Ignition is a flipswitch, turn the key on and flip a switch to activate starter, as ignition switch went out.
Apr 19, 2010 at 3:10 PM
