1993 Ford Escort Coolant Leaking
108,000 MILES • 4 CYL • FWD • AUTOMATIC
DP_123
When car is parked in the garage overnight, there is NO leak, however when turned and warm it leaks. The leak on drivers side front , under the radiator. Leak stops when parked again? Coolant light does NOT come on? Car runs fine, no unuual sounds. What could be the problem? thanks
Dec 21, 2009 at 4:45 AM
BMRFIXIT
  • 19,053 POSTS
Suspect radiator
coolant system need to be pressure checked
Dec 21, 2009 at 9:39 AM
