1993 Ford Escort Brake Lights
TCARSON
1993 Ford Escort
With the headlights off, and the brake depressed, one light is bright and the other dim. Same situation with the headlights on, one brake light is bright and the goes out altogether.
May 6, 2010 at 11:13 PM
  • 110,248 POSTS
This sounds like a ground problem. Have you checked it for that?
May 6, 2010 at 11:39 PM
TCARSON
[quote:75cf377eeb="Jacobandnickolas"]This sounds like a ground problem. Have you checked it for that?[/quote:75cf377eeb]
Not sure how to do that.
May 7, 2010 at 12:23 AM
  • 110,248 POSTS
Run a seperate ground to the light that isn't working properly.
May 7, 2010 at 1:03 AM
