1993 Ford Escort Back up lights
168,000 MILES • 4 CYL • FWD • MANUAL
SAGITTARIANSROCK
Hi
I found out that my back up lights are not working. Since all other lights (including those on the same fuse) are working, I am guessing it is either the electrical connection to those lights or the bulbs that is the problem. However, I cannot figure out how to get the bulbs out of the sockets.
The lights are situated at the base of the trunk hood. If someone can help me out with the instructions, I will be very happy to take pictures when I do it and post pictures. It seems that if there were some pictures somewhere it would be easy enough to do it :)
Thanks a lot for your help
Aug 12, 2009 at 8:18 AM
LAZYGAZER
  • 68 POSTS
Hi to replace your bulbs,first remove the 3 screws that hold the assy down then gently slide the assy upwards and that should give you access to the bulbs and sockets.
Aug 12, 2009 at 12:35 PM
