1993 Escort - high beams work, low beams do not
MALCHEV
1993 Escort, 92,000 miles. High beams work but low beams do not. What should I do? Thanks!
Jan 2, 2006 at 11:46 AM
DJ-TAINO
  • 12 POSTS
These cars came with really bad switches,Fire starting switches,Replace the switch.Which is located inside the car.Also can possible be the lever that turn the high beams on or off. Go to junk yard and p/u the two parts and replace.They are very expensive new.Good luck.
Jan 12, 2006 at 12:55 PM
