1991 Ford Escort Lots of things
230,000 MILES • 4 CYL • 2WD • MANUAL
SPIKE568
Not sure whether it is Engine or Coolant problem, maybe both. Engine starting making noises,sounding like a diesel. Check coolant light came on, went for an oil change and told them to check coolant, they filled it up. They said there was a small oil leak. Engine started overheating. Now car won't even start, I charge the battery and it starts but I turn the car off and it won't start again. Not sure what the problem is or if there are several problems there.
Feb 15, 2009 at 7:09 AM
BMRFIXIT
  • 19,053 POSTS
When you say not starting ,does it crank but will not start ?
check battery terminals ,check starter ,if start and all OK
remove spark plugs and check if its crank
let me know
Feb 15, 2009 at 1:12 PM
SPIKE568
It doesn't crank, it does nothing, no sound, nothing.
Feb 15, 2009 at 1:25 PM
BMRFIXIT
  • 19,053 POSTS
No power at all ,when key on (check battery terminals make sure its clean and tight )
make sure battery fully charged
if power ok it just will not crank
check starter and clutch switch (located at top of the clutch paddle )
Feb 15, 2009 at 1:39 PM
