1991 Ford Escort FUEL CUT OFF LIGHT
1991 FORD ESCORT
153,000 MILES • 4 CYL • 2WD • AUTOMATIC
JESSB1986
CAR DROVE GREAT, PARKED IT AND NOW FUEL CUT OFF LIGHT IS ON, ENGINE HAS SPARK BUT WONT START. CHECKED THE FUEL SHUT OF RESET BUTTON AND THE CAR CONTINUED NOT TO START. CHECKED FUSES UNDER HOOD. ALL FUSES WHERE GOOD. CAR RAN GREAT AND NOW IT WONT START AT ALL.
Nov 21, 2008 at 5:08 PM
DAVE H
  • 13,384 POSTS
make sure button is fully depressed on switch ....
INERTIA SWITCH
In event of a collision, electrical contacts in inertia switch open and fuel pump automatically shuts off. Fuel pump will shut off even if engine does not stop running. Engine will stop due to lack of fuel.
Engine cannot be restarted until inertia switch is manually reset. To reset inertia switch, depress button on switch. Inertia switches may be found in the following locations:
On Crown Victoria and Grand Marquis station wagon models, in the left rear side storage compartment.
On RWD vehicles (except wagons), in trunk, on the left hinge support or behind trim panel.
On Sable and Taurus, on left side of trunk (except station wagon).
On Taurus and Sable station wagon models, behind access door in right rear cargo area.
On all other vehicles, in trunk on left hinge support or behind trim panel.
Nov 22, 2008 at 12:17 AM
