1991 Ford Escort Clutch
95,000 MILES • 4 CYL • 2WD • MANUAL
RAUCH4428
When I drive I have to turn the car off to pu it into first and if I drive I have to slam it into 2nd and it grinds and i replaced the clutch slave cylinder but the clutch is still not working. It has a new transmission.
Jan 17, 2010 at 6:51 PM
  • 75,988 POSTS
If the clutch master cylinder is okay and the hydraulic was bleed properly and free play/pedal height adusted You need a new clutch assembly
Jan 17, 2010 at 7:08 PM
