Hi kool-rider
Neded to do some testing and info gathering.
Type battery
Group size
CCA rating
Are batteries going dead then you are charging them up repeatdly?
Need to do a battery drain test. Remove the negative cable place meter in series from term to cable end. Have meter set on amp scale 10 amp range. Make sure everything is off and door closed. Now hook up meter does it read.5 amps or higher? If not switch to mA amp scale do you read higher than.5 mA. If so start pulling fuses till amp gague reads less than.3mA.
Is battery hold down secure?
Let me know
Thursday, September 11th, 2008 AT 11:12 AM
