1989 Ford Escort slipping clutch?
114,011 MILES • 4 CYL • FWD • MANUAL
TERRIE DAY
when shifting into 2nd or 3rd, i depress the clutch pedel, shift, release the pedel,it shifts then sorta slips as i ecelerate then catches up with itself and works fine til i shift into 3rd same thing doesn't do it in 4th or 5th gear HELP! Thanks Terrie
Jan 21, 2008 at 4:25 AM
MUSTANG87
  • 261 POSTS
yes sounds like your clutch is on its way to death.but it can also be a oil leak in the main seal on motor and leaks into disk and makes it slipp a litttle.check for oil leaks.but even if its just an oil leak best thing to do is install a new cluch.for me it sounds like a clutch tho.
Jan 21, 2008 at 7:28 AM
