Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Escort
Engine
Symptoms
Stall at Idle
1989 Ford Escort problem
1989 FORD ESCORT
130,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBERTBOND
MEMBER
the car will start if you prime the bowl and keep giving it gas but will not idle. replaced the fuel pump. what do you think it is.
Mar 4, 2008 at 8:45 AM
MASTERTECHTIM
Experienced Mechanic
are you sure it has a carburetor?
Mar 4, 2008 at 8:50 AM
MASTERTECHTIM
will it stay running if you give it gas or only when pouring it in engine?
Mar 4, 2008 at 8:52 AM
ROBERTBOND
MEMBER
[quote:d9d29043e6="mastertechtim"]will it stay running if you give it gas or only when pouring it in engine?[/quote:d9d29043e6]
if you give it gas it will run but will not idle
Mar 4, 2008 at 8:56 AM
ROBERTBOND
MEMBER
it will run giving gas but not idle
Mar 4, 2008 at 9:07 AM
MASTERTECHTIM
well you either have a bad idle air control valve or a vacuum leak. most likely a stuck idle air control valve. hope this helps
Mar 4, 2008 at 9:12 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
