1988 Ford Escort Noises fuel pump
108,000 MILES • 4 CYL • 2WD • MANUAL
HOTFORD
My Ford Escort makes this noise ( Buzzing noise)from the fuel pump as soon as I start the car and continues while running....any thoughts out there...suggestion !
Nov 22, 2009 at 11:11 AM
  • 31,937 POSTS
Hi there,
sounds like a faulty valve in the pump, this will not be serviceable, you will need a new pump, i have have a number of noisy pumps through my workshop, and i would say in every case a new pump fixed the problem, also a noisy pump is a sign that something is starting to fail, and pump failure may not be that far away.
Mark (mhpautos)
Nov 22, 2009 at 1:27 PM
